Using Toleranced Dimensions in Notes
adchampion
Is it possible to insert a toleranced dimension into a note on a drawing? I tried using the real dimesion (with the tolerance already defined) as well as a dimension I created just in the drawing and in both cases the note only show the nominal dimension. I am trying to create a note that calls out the hole pattern on an API flange.
SW 2004, SP3.0
Ben Holgate
Woodgroup Pressure Control
As far as I know, you cannot "implant" the tolerance into a note ... just the dimension. You will have to add the tolerance manually.
[cheers] & all the best.
I agree w/CBL. Also in 2005 you can add top/bottom fractions to notes.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 05 SP0.1 / PDMWorks 05
