I'm trying to understand the the typical detail where a basement slab-on-grade meets a basement wall. Everywhere I see this joint discussed, an expansion joint material is called for to isolate the slab from the wall. This allows shrinkage (horiz. movement) or vertical movement of the slab (settlement, or swell) without affecting the wall.
What I'm confused about is it's typical practice to assume that the slab restrains the bottom of the concrete wall. How does the slab brace a wall if there is an expansion joint material, or the slab may have shrunk away from the wall some amount?
I've searched this forum, as well as general web searches. ACI 302.1 (3.2.5.1) and ACI 224.3 (5.3) both call for these isolation joints, but don't discuss the load path of the slab supporting the wall.
How do people deal with this? It doesn't appear to be a problem. Basement walls everywhere are being braced by slabs that were installed with compressible expansion joint material. I'd just like to better understand the load path and preferred materials.
Thanks!
Thanks!
