ollie24
- Oct 4, 2018
- 4
So I am creating a Mathcad 15.0 template to design a concrete foundation for a small 16ft x 36ft building. Designing the foundation is just fine. What I am trying to incorporate in the template is allowing the user to use Risa (not Risa foundation) to apply the load cases and combinations to the Risa model (typical roof live and dead loads, snow and wind, wall dead load, floor live and dead load). The foundation is a continuous concrete foundation wall below grade with a footing. The floor is a concrete slab with 2 spread footings. There are 28 anchor bolts total around the foundation perimeter. If part of the design process includes creating a Risa model, can the user (me for now) end up with a distributed load along the top of the foundation wall (and then incorporate that load into the Mathcad template)? Or should I place pins at the locations of the anchor bolts and simply come up with reactions at each pin? What do you recommend? I don't want to simply get reactions at all those pins, but that is all I have been able to work out so far. Thanks in advance!
