Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
[COLOR=green]'Date: 09/30/2010[/color]
[COLOR=green]'Subject: Sample NX Open .NET Visual Basic routine : demo select all objects of given types[/color]
[COLOR=green]'[/color]
[COLOR=green]'Note: GTAC provides programming examples for illustration only, and[/color]
[COLOR=green]'assumes that you are familiar with the programming language being[/color]
[COLOR=green]'demonstrated and the tools used to create and debug procedures. GTAC[/color]
[COLOR=green]'support professionals can help explain the functionality of a particular[/color]
[COLOR=green]'procedure, but we will not modify these examples to provide added[/color]
[COLOR=green]'functionality or construct procedures to meet your specific needs.[/color]
[COLOR=blue]Function[/color] getAllObjectsByTypes(ByVal whatTypes() [COLOR=blue]As Integer[/color]) [COLOR=blue]As[/color] DisplayableObject()
[COLOR=blue]Dim[/color] objList [COLOR=blue]As[/color] ArrayList [COLOR=blue]= New[/color] ArrayList
[COLOR=blue]Dim[/color] thisType [COLOR=blue]As Integer =[/color] 0
[COLOR=blue]Dim[/color] thisSubType [COLOR=blue]As Integer =[/color] 0
[COLOR=blue]For Each[/color] obj [COLOR=blue]As[/color] DisplayableObject [COLOR=blue]In[/color] s.Parts.Work.Views.WorkView.AskVisibleObjects
ufs.Obj.AskTypeAndSubtype(obj.Tag, thisType, thisSubType)
[COLOR=blue]For Each[/color] aType [COLOR=blue]As Integer In[/color] whatTypes
[COLOR=blue]If[/color] aType [COLOR=blue]=[/color] thisType [COLOR=blue]Then[/color]
objList.Add(obj)
End [COLOR=blue]If[/color]
[COLOR=blue]Next[/color]
[COLOR=blue]Return[/color] objList.ToArray(GetType(DisplayableObject))
End [COLOR=blue]Function[/color]
[COLOR=green]'eng-tips thread561-335918[/color]
[COLOR=green]'select displayed arcs, do something based on arc radius[/color]
[COLOR=blue]Option Strict Off[/color]
[COLOR=blue]Imports[/color] System
[COLOR=blue]Imports[/color] NXOpen
[COLOR=blue]Module[/color] Module1
[COLOR=blue]Sub[/color] Main()
[COLOR=blue]Dim[/color] theSession [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
[COLOR=blue]Dim[/color] workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] theSession.Parts.Work
[COLOR=green]'Get visible objects in work view[/color]
[COLOR=blue]Dim[/color] visibleObjects() [COLOR=blue]As[/color] DisplayableObject
visibleObjects [COLOR=blue]=[/color] workPart.Views.WorkView.AskVisibleObjects
[COLOR=blue]Dim[/color] tempArc [COLOR=blue]As[/color] Arc
[COLOR=blue]For Each[/color] tempObj [COLOR=blue]As[/color] DisplayableObject [COLOR=blue]In[/color] visibleObjects
[COLOR=green]'test if object is an arc[/color]
[COLOR=blue]If TypeOf[/color] tempObj [COLOR=blue]Is[/color] Arc [COLOR=blue]Then[/color]
tempArc [COLOR=blue]=[/color] tempObj
[COLOR=blue]If[/color] tempArc.Radius < 5 [COLOR=blue]Then[/color]
[COLOR=green]'do something with small arc[/color]
tempArc.Blank()
[COLOR=blue]Else[/color]
[COLOR=green]'do something else with large arc[/color]
End [COLOR=blue]Sub[/color]
End [COLOR=blue]Module[/color]
'eng-tips thread561-335918: Using journal to select all: Using journal to select all
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.uf
Imports NXOpen.utilities
Imports NXOpen.Assemblies
Imports System.Windows.Forms
Imports System.IO
Imports System.Collections
Imports System.Environment
Imports NXOpenUI
Module Module1
Sub Main()
Dim S As Session = Session.GetSession()
Dim workPart As Part = S.Parts.Work
Dim ufs As UFSession = UFSession.GetUFSession()
Dim selobj As NXObject
Dim arc1 as ibasecurve
dim cpoint as point = nothing
dim kk as integer=0
Dim type As Integer
Dim subtype As Integer
Dim lw As ListingWindow = s.ListingWindow
Dim layerObjects() As NXObject
Dim layerObjectsDisplayable() As DisplayableObject
Dim layerColorID(256) As Integer
layerColorID(1) = 6
Dim visibleObjects() As DisplayableObject
visibleObjects = workPart.Views.WorkView.AskVisibleObjects
Dim tempArc As Arc
Dim displayModification1 As DisplayModification
displayModification1 = S.DisplayManager.NewDisplayModification()
'displayModification1.NewColor = layerColorID(1)
'displayModification1.NewFont = DisplayableObject.ObjectFont.LongDashed
displayModification1.NewWidth = DisplayableObject.ObjectWidth.Thick
displayModification1.ApplyToAllFaces = True
displayModification1.ApplyToOwningParts = False
For Each tempObj As DisplayableObject In visibleObjects
If TypeOf tempObj Is Arc Then
tempArc = tempObj
If tempArc.Radius < 1 Then
Dim objects1(0) As DisplayableObject
objects1(0) = temparc
displayModification1.Apply(objects1)
displayModification1.Dispose()
End If
End If
Next
End Sub
End Module
tempArc = tempObj
End If
End If
Next
End Sub
[COLOR=blue]Imports[/color] NXOpen.UF
[COLOR=blue]Imports[/color] NXOpen.Utilities
[COLOR=blue]Imports[/color] NXOpen.Assemblies
[COLOR=blue]Imports[/color] System.Windows.Forms
[COLOR=blue]Imports[/color] System.IO
[COLOR=blue]Imports[/color] System.Collections
[highlight #EDD400][COLOR=blue]Imports[/color] System.Collections.Generic[/highlight]
[COLOR=blue]Imports[/color] System.Environment
[COLOR=blue]Imports[/color] NXOpenUI
[COLOR=blue]Dim[/color] S [COLOR=blue]As[/color] Session [COLOR=blue]=[/color] Session.GetSession()
[COLOR=blue]Dim[/color] workPart [COLOR=blue]As[/color] Part [COLOR=blue]=[/color] S.Parts.Work
[COLOR=blue]Dim[/color] ufs [COLOR=blue]As[/color] UFSession [COLOR=blue]=[/color] UFSession.GetUFSession()
[COLOR=blue]Dim[/color] selobj [COLOR=blue]As[/color] NXObject
[COLOR=blue]Dim[/color] arc1 [COLOR=blue]As[/color] ibasecurve
[COLOR=blue]Dim[/color] cpoint [COLOR=blue]As[/color] point [COLOR=blue]= Nothing[/color]
[COLOR=blue]Dim[/color] kk [COLOR=blue]As Integer =[/color] 0
[COLOR=blue]Dim[/color] type [COLOR=blue]As Integer[/color]
[COLOR=blue]Dim[/color] subtype [COLOR=blue]As Integer[/color]
[COLOR=blue]Dim[/color] lw [COLOR=blue]As[/color] ListingWindow [COLOR=blue]=[/color] s.ListingWindow
[COLOR=blue]Dim[/color] layerObjects() [COLOR=blue]As[/color] NXObject
[COLOR=blue]Dim[/color] layerObjectsDisplayable() [COLOR=blue]As[/color] DisplayableObject
[COLOR=blue]Dim[/color] layerColorID(256) [COLOR=blue]As Integer[/color]
layerColorID(1) [COLOR=blue]=[/color] 6
[highlight #EDD400][COLOR=blue]Dim[/color] arcList [COLOR=blue]As New[/color] List(Of Arc)[/highlight]
[COLOR=blue]Dim[/color] displayModification1 [COLOR=blue]As[/color] DisplayModification
displayModification1 [COLOR=blue]=[/color] S.DisplayManager.NewDisplayModification()
[COLOR=green]'displayModification1.NewColor = layerColorID(1)[/color]
[COLOR=green]'displayModification1.NewFont = DisplayableObject.ObjectFont.LongDashed[/color]
displayModification1.NewWidth [COLOR=blue]=[/color] DisplayableObject.ObjectWidth.Thick
displayModification1.ApplyToAllFaces [COLOR=blue]= True[/color]
displayModification1.ApplyToOwningParts [COLOR=blue]= False[/color]
[COLOR=blue]If[/color] tempArc.Radius < 1 [COLOR=blue]Then[/color]
[highlight #EDD400]arcList.Add(tempArc)[/highlight]
[highlight #EDD400][COLOR=blue]If[/color] arcList.Count > 0 [COLOR=blue]Then[/color][/highlight]
[highlight #EDD400] displayModification1.Apply(arcList.ToArray)[/highlight]
[highlight #EDD400]End [COLOR=blue]If[/color][/highlight]
[highlight #EDD400]displayModification1.Dispose()[/highlight]
