McDermott1711
- Nov 17, 2010
- 318
Hi everybody,
One of valve suppliers in a project, mistakenly used jam nut (instead of regular heavy hex) in a series of DBB valves (due to limited space). Now Clinet asked him to present calculation which shows it is still satisfactory. The valve is designed under API 6D and the jam nuts are made of ASTM A194 Gr. 2H. Is it ok to make the calculation on the following basis?
1- Find worst (largest) gasket area, multiply design pressure by this area to get total force.
2- Divide total force by total nuts to get per/nut force.
3- Add this force to the tightening pre-load.
4- Compare the result with proof load of corresponding one from ASTM A194 for a Gr. 2H, jam nut.
If so,
1- What design pressure shall be considered for a class 1500 valve?
2- What tightening pre-load shall be considered for, say, a 9/16 nut?
Any help will be highly appreciated.
Nothing is more fairly distributed than common sense: no one thinks he needs more of it than he already has. Rene Descartes
If so,
