RealSaladsamurai
Hi All - I am using the above configuration (not my choice) with FEMAP 11.1.0. When I request the mass participation factors under Analysis Set > Options > Modal XYPlot > Edit > Modal Effective Mass fraction = ON it does not print the results into the f06 file nor does it import to FEMAP as funcions.
I have to manually go into the .bdf file and make the following change:
(why does FEMAP write the command to file as "NOPRINT" ??? Seems like a bug...)
TO:
When I then pull results back into FEMAP, I cannot use the XY capability to plot functions since the functions are not created (due to the manual operation).
Is there a workaround for this to get FEMAP to read the fractions into functions? Manually copying/pasting into Excel is kind of a bummer. It's much better practice to keep all results self contained where possible. Thank you!
NX7.5.5.4 - Teamcenter 8
ANSYS Workbench 14.5
Code:
MEFFMASS(NOPRINT,GRID=0,FRACSUM) = YES
TO:
Code:
MEFFMASS(PRINT,GRID=0,FRACSUM) = YES
