Using EKL to create a note linked to the flagnotes in a part
Jeremy.H
Student
AU
I am brand new to the enterprise knowledge language. I am trying to use the notify function in order to obtain all the content in the flagnote section of a part. Suggestions welcome to any other functions that will let me find the flagnotes and then provide their value.
At this stage I am simply using the notify function with a copy paste of the text, straight from the functions provided in the library.
let i = 1
Notify("NOTES:| ->1.MATERIAL: ALUMINUM ALLOY 7071 T651| ->3. BREAK ALL SHARP EDGES 0.2 RAD MAXIMIUM UNLESS OTHERWISE STATED. ->4. FOR FEATURES NOT DIMENSIONALLY DEFINED REFER TO CAD MODEL.| ->
6. TAP USING RECOIL TAP NUMBER 43605 AND INSTALL INSERTS ITEM 3 USING RECOIL INSTALLATION TOOL NUMBER 53601.
TOP FACE OF INSERTS TO BE INSTALLED 0 T0 0.2 MM BELOW FACE.
5. SEE SHEET 2 AUXILIARY REAR VIEW FOR MORE DETAILS.| ->7. TAP USING RECOIL TAP NUMBER 43585 AND INSTALL INSERTS ITEM 4 USING RECOIL INSTALLATION TOOL NUMBER 53581.
TOP FACE OF INSERTS TO BE INSTALLED 0 T0 0.2 MM BELOW DATUM A FACE.| ->
8. TAP USING RECOIL TAP NUMBER 45045 AND INSTALL INSERTS ITEM 2 USING RECOIL INSTALLATION TOOL NUMBER 55041.
TOP FACE OF INSERTS TO BE INSTALLED 0 T0 0.2 MM BELOW FACE.")
for i while i < 3
Notify("i = #", i)
Any help would be really great!:)
