dogarila
- Oct 28, 2001
- 594
handleman said:Here's some code out of an Excel sheet I used to update all custom properties from an old job to a new job. I wrote this as a one-time shot, so it's pretty brute-force, and could use more comments. Basically, it uses a text file as input for the names of the files to edit. It then searches each custom property (regardless of its name) for specific strings and replaces them with different ones. I had it dump the custom prop name, old value, and new value to the Excel sheet so I could do a quick visual check.
Of course, for this to work you have do download and register the dll first, and include it in the references.
Hope this helps!
-Josh
Code:Sub DoTheSwap() Dim PropReader As DSOleFile.PropertyReader Dim DocProps As DSOleFile.DocumentProperties Dim CustProp As DSOleFile.CustomProperty Dim PropVal As String Dim fso As Scripting.FileSystemObject Dim sFile As String Dim sFilesPath As String Dim sFilesList As Scripting.TextStream Dim CurPath As String Dim OldJobNo As String Dim NewJobNo As String Dim OldProjName As String Dim NewProjName As String Dim OldMcNo As String Dim NewMcNo As String Dim OldDrawn As String Dim NewDrawn As String Dim CurRow As Long sFilesPath = "C:\Documents and Settings\tnjbrady\Desktop\out.txt" Set fso = CreateObject("Scripting.FileSystemObject") Set sFilesList = fso.OpenTextFile(sFilesPath, ForReading) Set PropReader = New DSOleFile.PropertyReader OldJobNo = "TC04152" NewJobNo = "TC05083" OldMcNo = "AS134" NewMcNo = "AS144" OldProjName = "STEPPER SUB-ASSY CELL" NewProjName = "STEPPER SUB-ASSY #2" OldDrawn = "John Doe" NewDrawn = "Jim Smith" CurRow = 1 While Not sFilesList.AtEndOfStream CurPath = sFilesList.ReadLine Set DocProps = PropReader.GetDocumentProperties(CurPath) For Each CustProp In DocProps.CustomProperties On Error GoTo SKIP PropVal = CustProp.Value ActiveSheet.Cells(CurRow, 1).Value = CustProp.Name ActiveSheet.Cells(CurRow, 2).Value = PropVal PropVal = Replace(PropVal, OldJobNo, NewJobNo) PropVal = Replace(PropVal, OldProjName, NewProjName) PropVal = Replace(PropVal, OldMcNo, NewMcNo) PropVal = Replace(PropVal, OldDrawn, NewDrawn) CustProp.Value = PropVal ActiveSheet.Cells(CurRow, 3).Value = PropVal CurRow = CurRow + 1 SKIP: Next Wend End Sub
This answer was in a previous thread but I think I should open a new one.
I copied and pasted the above code in a macro, in Excel. I downloaded dsofile from Microsoft site, installed it, registered the dll, checked out the reference in Excel VBA and run it. It stops at
Code:
Is there anything else I need to do before using DSOfile?
