arh13p
Agricultural
- Mar 25, 2009
- 32
I have an existing 80' steel flag pole. 14" at the base and tapers to 3.5" at the top. The base of the pole is encased in an 8' deep sleeve, 18" dia. with 2" bank sand filling around the pipe. The base is encased in concrete and the pedastal is granite with a granite platform and steps around it(20' diameter). The pole needs to be replaced and was wondering if re-using the base is practical. It appears the wedges could be removed and the pole removed. I was thinking water jetting and vacuum truck could get the sand cleaned out of the sleeve and a new pole installed with a new grounding apparatus. Has anyone done this or have any suggestions. I was hoping to reclaim the granite and have the final product look as it did, just a new pole. Thanks!
