We've got a lab trailer that is being rebuilt. The mfgr assembled it with a protecting underbelly of 24Ga 5052 aluminum sheet with aluminum rivets into the steel frame.
After six years the frame is rusted and the underbelly has numerous through-holes from corrosion, and is being removed. I'd like to spec stainless sheet to replace the protective bellypan.
I've got enough SS304 in 24ga to do the job, and would isolate the stainless sheet from the (now restored and painted) steel frame using butyl rubber and mount using SS316 rivets.
Will SS304 work in this application, or would I best use 316 sheet? I'm not overly concerned about surface finish, but don't want a recurrence of corrosion. The trailer does get exposed to chlorides from salt spray and road salt, but if isolated, will this be a problem?
