User Defined Attributes
  • Thread starter Thread starter mec
  • Start date Start date
M
mec
Guest
My user defined attributes do not appear in my drawing formats. I can select these attributes from the table figuration in Intralink. Is there some switch/command I'm missuing.
You need to do 2 things.
Firstly make sure that your attributes (otherwise known as parameters) are designated. You can do this in PROE select SETUP#PARAMETERS#DESIGNATE and pick all your user defined parameters.
Next to get them to appear on your drawings you need to enter text onto the drawing format in the form of parameter notes e.g. &pdm.rev fills in the value for the model revision on your drawing.
