Use of threaded rod as bolt material
NDT3RICH
Petroleum
Aug 19, 2015
12
May B7 threaded rod be used as cut to length ASTM A 193 stud material?
Well, what are the material spec's for strength for B7 and for ASTM A 193?
(Let's assume the two threaded rods are cut to the same dimensions. )
NDT3RICH, ideally you'd want to transfer markings to the cut end(s) if for Code use.
Mike
Yes. We do this all the time. Engrave the end with the grade for future reference.
