bthompson
- Mar 10, 2003
- 4
I have found specifications for valves (internal) where the Cv value of the valve is specified and the valve is almost exclusively used for gas application (dry Nitrogen). I haven't worked on this stuff for a while, so I reviewed the derivation of the classic Cv equation. This derivation assumes the fluid is incompressible. Check out fisherregulators.com - one of their "technical monographs" goes over this in excellent detail. For a new application, I know what my minimum flow requirements are and I know what my pressure range is. Why not simply stay away from Cv and specify flow and pressure? Is it appropriate to use Cv for gas application (obviously I think not)? If not, is there an equivalent term used for gas application?
