I have a non-structural application on a 747-400 aircraft where manufacturing has asked us to use 1100-F "A" rivets in place of the 2117-T3 "AD" rivets currently on our drawing.
My Boeing Liaison Engineering handbook from my days at Boeing says (on page 60.2.2) "Avoid using 5056 or 1100F rivets in 2000 series or 7000 aluminum. If used, they should be installed with sealant BMS 5-95. Use 2117 fasteners if possible..."
The bracket we are attaching to is 2024-T3. According to the note, I should avoid 1100F. 1100 alloy is a minimum 99% pure aluminum. In what way is it incompatible with 2000 or 7000 aluminums? Is this a corrosion issue? I understand "A" rivets are relatively weak at 9.5 ksi shear, but that is not an issue for this application. We're attaching a plastic air conditioning duct spacer to a 2024 bracket. I would prefer not to have to use the sealant here, and I don't understand why the sealant would be required.
Does anyone know the source of the Boeing note?
Brent
Brent
