Use Mechanism to move part up slope?
  • Thread starter Thread starter proed
  • Start date Start date
P
proed
Guest
We have many assemblies where most parts are cylindrical (oil/offshoreindustry) - and keys move up and down on sloped shoulders, etc.. The image should help explain (note: outer body hidden for clarity).
I'm trying to replicate this movement with Mechanism - experimenting with Cams, Slots, etc... haven't found a neat solution yet...
Can anyone help with this?
Thanks in advance
Ed
yeah pretty easy.
1. on the part that does the upand down sliding place a point on the leading bottem chamfer.(part-a)
2 on the part that moves from left to right create a datum curve
that goes along its surface (left to right ) (just use edit
->intersect-> select the datum and surfaces"
(part-b)
constrain
part-b default
part-a planar connection to that (left to right motion)
slot connection.
connect the point in part-a to the datum curve on part-b
driver
plane to plane
if you have trouble upload ur files :)
how does one get a cool job like that :)
Edited by: puppet
You should be able to use a cam and follower as well instead of the slot connection...
