Aug 11, 2023 #1 nashki Mechanical Joined Jun 5, 2023 Messages 25 Location SG Dear contributors, Is it possible to use ASME B16.5 flange (pressure rating) to design pressure vessel by EN 13445? Is there any specific requirement to be fulfilled?
Aug 11, 2023 #2 LittleInch Petroleum Joined Mar 27, 2013 Messages 22,988 Location GB Does EN 13445 allow use of ASME codes? If not then not really - look at the code very carefully to see or use the flange code it states. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Aug 11, 2023 #3 LittleInch Petroleum Joined Mar 27, 2013 Messages 22,988 Location GB And read this post which is basically the same question. https://www.eng-tips.com/viewthread.cfm?qid=510211 Looks like you need to use EN 1759, but get the flange dual certified to B16.5.... Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
Aug 11, 2023 Thread starter #4 nashki Mechanical Joined Jun 5, 2023 Messages 25 Location SG LittleInch, Yes, i have compared the B16.5 and EN 1759, but the EN not fully adopt the B16.5 For example, material A-182-F51 is not available in EN 1759, which is in ASME in the material group 2.8 Upvote 0 Downvote
Aug 12, 2023 #5 LittleInch Petroleum Joined Mar 27, 2013 Messages 22,988 Location GB Well you can't have everything! If you insist on using something only available in B16 5 and not an alternative then you can't do it using an EN PV code. Remember - More details = better answers Also: If you get a response it's polite to respond to it. Upvote 0 Downvote
