Use default template check box
  • Thread starter Thread starter Jodster
  • Start date Start date
J
Jodster
Guest
Hi all
I have a question about the check box that is on the UI for creating a new part. I would like the ability to have this unchecked by default.
We use several start parts based on the design and I would like the user to have to select which one to use. I am aware that if you don't include template_solidpart in the config.pro, you are forced to pick one, but this seems a little confusing.
Is anyone aware of a config setting that will un-check this by default?
I haven't seen a config setting for it but you could create a mapkey that starts a new part and unchecks the default box. Replace your existing button with the new mapkey and it will do that by default. It won't work for users who start parts with the file menu though.
