USB Rotary Table?
drozovs
Aerospace
Does anyone know of a rotary table manufacturer that is USB capable and can give position data?
I am trying to prototype a test system but I need the PC that will be running the system to command the tables position and receive information about where it is as well.
Any ideas or known companies?
Thanks!
And is there some reason you're withholding information about the performance you require and the size, weight, etc?
TTFN
FAQ731-376
You may try looking for a motorized rotary table and matching it with a controller with a USB interface.
See:
[link ]
btn_liprofile_blue_80x15.gif" width="80" height="15" border="0" alt="View Clyde's profile on LinkedIn
[/url]
Sorry, I would like the specs to be:
under 8 inches in diameter
no more than 6 inches in height
a holding force of 25lbs
360 degrees of freedom
15 degrees per second or more of travel
resolution of 0.1 degree with he same repeatability
Ill check that link too Clyde. Thanks IR!
