I am using PLS TOWER for modeling and designing transmission towers and I notice that they provide two sets of reactions for each support point of the tower model.
They provide customary x,y,z reactions at each support point, but also reactions in Direction of Leg. The TOWER manual appears to show that the two sets are equivalent as the Direction of Leg forces result from an angle transformation of the original x, y, z forces as displayed in the attached image.
Now, what I notice from the two sets of reactions is a) they indeed produce the same resulting reaction force (sqrt of the sum of the squares), b) they produce a value of axial force along the leg that is larger than the vertical force in the original x, y, z forces, but c) the residual shears produced in the Direction of Leg reaction set are much smaller (15% or less) than the horizontal forces in the original x, y, z set.
My questions:
1. What is the engineering meaning of these residual shears?
2. Is it normal practice to design tower foundations with the Direction of Leg set of reactions?
3. If so, do these residual shears have any use for the design of foundations or they are just neglected when checking stability and bearing capacity? Here I am most concerned about the reduction in the
eccentricity of the loads and their impact in the dimensions of foundations.
Your comments/impressions are much appreciated.
Trafo.
P.S. This is my first post in this forum, so sorry I am missing something in my initial description of the issue.
My questions:
Trafo.
