This is a common problem with vertical turbine pumps. It is more common with pumps that have a large number of stages. In order to allow for the downward thrust when running at normal flow rates, the manufacturers tend to add back wear rings and balance holes through the impeller. But, if the downward thrust is reduced when running at normal rates, it can easily reverse when running at very high flow rates. We see this with propane re-run pumps that have 25 stages. If they start the pump up into an empty line and run it beyond end of curve, the up-thrust will buckle the shaft and destroy the seal. For a six stage pump, I am surprised that the up-thrust is a problem. But, if the motor does not have any true thrust bearing for up-thrust, then it only takes enough to overcome the weight of the rotor. There was a very good article on up-thrust in this type of pump presented at the International Pump Users Symposium in 2005 or 2006. I don’t have a copy of the article handy.
Johnny Pellin
