MegaStructures
I am a licensed structural engineer specializing in steel and reinforced concrete, but my question is related to wood framing.
I have a friend building a residential home (CMU walls and wood-framed floors) who asked my opinion on placing a home gym on the second floor. I don't plan on stamping drawings or interjecting in the design process, but the topic got me thinking about how I'd approach the design myself.
Loading:
The plan is to frame the floor with engineered joists and a plywood subfloor. The EOR has stated that the equipment type and location must be known before designing the floor. While I agree it's ideal to know exact point loads, it’s unrealistic to assume the owner (or future owners) won’t move or add equipment. Instead, I think a more practical approach would be designing the entire gym floor for an increased live load (125-150 psf) and ensuring the subfloor can withstand a 2,000 lb. point load at any location.
Structural System Selection:
From reviewing the plans, it seems feasible to meet these loading demands using a wood joist system with joists at 16" o.c. and two layers of 3/4" plywood subfloor, fully glued and screwed. I would also recommend a thick rubber floor covering above the subfloor to absorb sound, vibration, and impact. My quick back-of-the-napkin calculations suggest that the plywood would be sufficient for both distributed and concentrated loads in terms of strength and serviceability.
Question:
For those with experience designing similar systems, I’d appreciate your insight on the following:
Loading:
Question:
- Does the assumed loading sound reasonable? I’ve seen 100 psf commonly cited for gymnasiums, but I aimed for conservatism with 125 psf.
- Does the proposed structural system seem sufficient for this application, or have you used a more suitable system in the past?
