Updating of Sheets
  • Thread starter Thread starter saravanans_87
  • Start date Start date
S
saravanans_87
Guest
Hi all,
I moved to Creo some two months back from wf5.
Now i found like the drawing updation from model only happens if we give 'update sheets'. Regeneration alone is not enough.
Is that true or am facing any bug here?.
Y am asking is, i dont remember this 'update sheet' option in wf5.I usuall do "regeneration" and that pulls all the updations of model to drawing.
Any thought ??
Check the config option "auto_regen_views"
it should be "yes" to update views immediately on switching windows.
Mallikarjun
We have auto_regen_views set to YES and it is still a problem. This seems like a bug. Anyone else?
The same here <?:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Creo 1.0 M030
I don't face this problem. Everything works fine. Creo 1.0
I am facing this problem with Creo 2.0
I am regenerating the drawing by using pro toolkit.
Even though the drawing is regenerating successfully when I open the drawing file manually and give update sheets the view is updating.
Any updates on this?
Regen is not the same as update.
I've always had to use update since WF 2.
