Updating list 1
dje71183
Industrial
This is my first time doing something like this so please bear with me.
I am trying to set up a program using VB in Excel.
I have a master list of parts and prices.
Sub lists made up of parts and prices from the master.
Both the master list and sub lists on same worksheet.
I want to be able to update the master list then have the program update the sub list.
How can I have the program look for the same part in the master list to match it up with the sub list and enter the new price that I put in the master?
Make sense?
If you do a VLOOKUP or INDEX - MATCH combination, you don't need any VB at all. There are many good examples available, also in this forum.
Cheers,
Joerd
Hi, dje71183, Joerd is completely right that you don't need VBA at all. Below is a simple example:
*** master list ***
1 2 3
A ID part price
B 1 p1 $12
C 2 p2 $13
Z 25 p25 $1
*** sublist ***
1 2 3 (column numbers)
ID VLOOKUP formula VLOOKUP formula
Formula =VLOOKUP(1,$B$1:$Z$3,2) will return name of part with ID equal to 1. Formula =VLOOKUP(1,$B$1:$Z$3,3) will return price of part with ID equal to 1.
You can set up your sublist in a similar format as the master list: ID in first column, and VLOOKUP formulas in the second and third columns to get you part name and price. First parameter of VLOOKUP formula would be a cell name in the first column - when you change the ID in the first column, correct part name and price will be displayed.
Hope this helps,
bridgeart
dje71183,
joerd is absolutely correct - no vba is required. furthermore, you may want to consider using what is termed "dynamic arrays" or "ranges". please see the following examples at:
hope this helps!
-pmover
a star for joerd!
It would be much better in a database though. Access even has a template (Inventory Control) for what you want.
