update PDM revision while drawing open
  • Thread starter Thread starter jeff toff
  • Start date Start date
J
jeff toff
Guest
Hi All,
In Intralink 3.2, if you changed the revision of a part and drawing with each open in ProE, you could just use the file replace command. Now I am using Intralink 3.4 but I can not find the same command to do this, I have been closing each file and erasing memory, reopen in order to get the &proi_revision to update.
Is there a easier way?
Thanks Jeff Toff
Hi All,
Just an update to the questionI posted. We updated ProE to M070 from M010. I found out how to updateparts, assemblies and the Drawing Revision from workspacewithout having to close/erase memory. You can pick on the part or assembly in the model tree, right click and pick update.
This function did not work with M010 version of ProE.
Hope this helps you out...
Jeff Toff
