update external links in CATIA part via a macro
josephv
683
Good afternoon, was wondering if there was a way to update the external links in a CATIA part via the API.
The way to do this in CATIA is:
Edit > Links > Load > Synchronize
Or use the Right Mouse button on a "linked" body and select "Local Update".
There is an UpdateObject method, but it does not appear to update external links.
Please forward your comments and suggestions.
Thank you,
Joseph
In tools--options--infrastructure--part infrastructure there is an option to automatically update external references as well as an automatic update.
Derek
Thanks Derek, good tip.
BTW we fixed this problem, by simply closing and then re-opening the part. Then the Update method works.
Best regards,
Joseph
Joseph - because your updates in your settings are set to manual, but another setting for update upon opening.
Derek
Hi Derek,
Thanks, we did change the settings as per your suggestion.
The part does update in CATIA perfectly, but does not when we run the macro. I am guessing there is an issue with the Update Method. However, we do have a work around, so I am happy with the end result.
Thanks again,
Joseph
