S
sharpn
Guest
I am new to autocad and this forum so 'Hello all'.
I am using the 4-viewport 3d view for creating objects (The top,left,front and isometric views) And when I try to move a '2x4' to a 'post' it will look correct in the view I am working in. But in actuality the board will be moving a number of inches (or sometimes feet) in the 'z' direction for that view. Meaning that I want to use the move command to move an object 6 inches to the right, but it will move 6 inches to the right and 32.5 inches 'down' (into the screen.)
Is there any way that I can restrict the movement of objects to the plane that I am looking at? So the top-down view would only allow them to move left,right,up and down and not change in height (z-position) at all.
This is becoming a GREAT source of frustration for me. Any help at all will be greatly appreciated.
Thank you all.
Thank you all.
