Unrotate global axis in upper geometry 1
engjeff
Automotive
Apr 24, 2007
84
Somehow the global axis of an upper product got rotated. I have other products tied in associativity and now Horizontal and Vertical is no longer the same as in the Upper Geometry.
My question is how can I change either the global axis of the upper assembly or change each of the parts to match the upper product?
I have an assembly that I have worked on for months and now it is all messed up. I really could use someones help.
engjeff, i will give it a shot. when you say upper product i am assuming this is the top product, i will address it as Product A. You have Sub products B and C. If your entire assembly is still visually correct but dimensional wrong you could make Product A into an sub product by inserting it into a new Product D. You could then use the compass to move and rotate Sub Product A back to the correct location.
I need some feedback before I make another suggestion
Do you have constraints between products? Are you designed in context of the assembly - basically a skeleton design?
Derek
Thank you for the link to the other forum. That worked it just took some work. Thank you both for the replies.
