We've been having problems with some bearings in cryogenic hydrogen service ( -420 F). The bearing is in the liquid hydrogen flow stream and can not be lubricated.
Size: 20 mm ID, 47 mm OD, 14 mm wide.
Style: Roller
Speed: 12,000 RPM
No lubricant.
Operating temp: -420 F
Load: Indeterminate, supports rotating pump shaft. No large radial loads. Weight supported may be aprox. 10 pounds.
I've gotten some quotes back on a replacement bearing.
1'st quote:
Ceramic rollers, corrosion resistant high nitrogen steel, Teflon impregnated PEEK cage, C5 clearance.
2'nd quote:
Corrosion resistant, high nitrogen steel rings and rollers, glass filled Teflon cage with molybdenum disulfide added, C5 clearance.
Both bearings have the same load rating which is on the order of 5000 pounds.
Any thoughts on what might work best for this application would be appreciated.
Style: Roller
Speed: 12,000 RPM
No lubricant.
1'st quote:
2'nd quote:
