Single Phase .....
Permanent split capacitor....
Permanent split capacitor (PSC) motors do not have a starting switch or a capacitor strictly for starting. Instead, permanent split capacitor motors have a run-type capacitor that is permanently connected in series with the start winding. This makes the start winding an auxiliary winding after the motor reaches running speed.
Because the run capacitor must be designed for continuous use, it cannot provide the short-term "boost" of a starting capacitor. Therefore, starting torque of a PSC motors is low, ranging from 30 to 150 percent of rated load, which makes the motors unsuitable for hard-to-start loads. However, unlike split-phase motors, PSC motors have low starting currents, usually less than 200 percent of rated full-load current, making them excellent for applications with high cycle rates.
Permanent split capacitor motors have several advantages: since they do not require a starting mechanism, they can be designed for easy reversing. They can also be designed for optimum efficiency and high power factors at rated load. They are considered to be the most reliable single-phase motors, primarily because a starting switch is not required.
Permanent split capacitor motors have a wide variety of applications depending on the design. Examples include direct drive fans, blowers with low starting torque requirements and intermittent cycling applications such as adjusting mechanisms, valve actuators, gate operators and garage door openers, many of which also require reversing.
