Hi ramshanpad and welcome on the forum.
As I know You can check upthe basic properties of model with Model Analysis.
Just follow thesefew steps in this short Tutorial:
1) Create some simple modelin some units. For example, I used (FPS=Foot Pound Second)
2) From dashboard select Analysis/Model Analysis and than click on the COMPUTEbutton as you can see on the next figure. Model masswas computed. (By the way, you can see more results like Volume,Surface Area, Density, Center of gravity and so on...) But hese results are only in your units (As I wrote earlier I used,in my example FPS units)
3) Save your analysis and change the units of the model by this method> From dashborad select EDIT/SETUP/UNITS and insert (mmNs=milimeter Newton Second). Click SET... andselect"Convert dimensions (for example 1" becames 25.4mm)".Now is your model recalculated toother units.
4) Now repeat the ModelAnalysis and save your results. The properties of your model was recalculated in other units(From FPS to mmNs).
Good luck!
Edited by: Miko
