Unigraphics Unit convertor 3
karthikj
IN
Hi all ,
If you need to convert your already created part file from inches to mm or viceversa ,check out this application,
it is easy and helpful
regards,
karthikeyan.J
Just be careful if you have multiple versions of UG on your workstation. The program uses UGII_BASE_DIR to locate ug_convert.exe, which is what does the actual conversion.
All this program is a GUI front end to an existing UG utility.
Ben Loosli
CAD/CAM System Analyst
Ingersoll-Rand
