I have a menu that I have created to modify the values of an object, length, width and etc as well as change the attributes of the object for the BOM. Each buttom calls out for the value of an expression to be changed. The expression value in the object is 1 for Alunimum and 2 for Stainless Steel. If the user selects the button for Aluminum and in the macro the original value was 1, the macro errors out. If they Select Stainless Steel it works fine. It needs to switch back and forth between 1 and 2. I am trying to fine some way to keep this from happening. Its OK with me but other users might not understand what is happening.
On another note, I would like to be able to get the part number attribute for the BOM as well.
Larry Leonard
Designer
Smith-Nephew Orthopaedics
