HamburgerHelper
Can someone explain to me what happens when you have CTs for each phases connected to the relaying with an ungrounded wye connection? The neutral was left open and I suppose for a balanced system it wouldn't matter since the neutral would only carry zero sequence current. It was discovered as part of an investigation into a CT failure I believe. To me, it looks like an ungrounded wye would screen out any zero sequence current but you would have zero sequence voltages develop across both sides of the relaying. I don't think there is an issue with saturation. Can this cause that? Can the ungrounded neutral voltage bounce around so much to cause the CT to fail?
