Per
2.1.1.1 Positional Tolerancing Method. Preferably, tolerances on dimensions that locate featues of size are specified by the positional tolerancing method described in Section 5. In certain cases, such as locating irregular-shaped features, the profile tolerancing method describe in Section 6 may be used.
This lays out that the preferred method of locating features of size is the positional tolerance, and that profile of a surface may be used as the alternative. Where does it say anything about using +/- conventional tolerances to locate anything? If someone feels that 2.1.1(a) applies to the location of a feature of size, please back it up somewhere else in the standard with text or graphic.
This issue keeps coming up
![[banghead] [banghead] [banghead]](/data/assets/smilies/banghead.gif)
because the use of Preferably, Must, Shall, Should, May and other such terms is not widely understood within the context of legal documents. The terms do not have the same meaning as in conversational english. In this case, "preferably" is an indicator of the primary methodology, and establishes such methodology in a discrete statement. Acceptable alternatives are subsequently indicated in follow-up statements. It doesn't give you latitude to use any other method than what is listed.
Also consider that a "centerline" or "center" of a feature isn't physically present and reproducible without going back to the feature itself. Grab the axis of a hole! How are you going to find that hole's center repeatably? ASME addresses how to find the position of the center (axis or plane(s)) for features of size, but doesn't give any indication of methodology for verifying a +/- location. What about tying the feature's position to the datums? To invoke a datum reference you typically use a FCF. But +/- tolerances on location dimensions to the side of the workpiece are point-to-point, not center to datum. There's not one graphic or text anywhere in the book supporting the use of +/- location tolerances for features of size.
Off the soapbox now.
So, to the OP, if you're invoking Y14.5M-1994 or its ancestors, then you are bound to one of those two positioning methods. As you're not looking for a cylindrical tolerance zone, you can use separate "vertical" and "horizontal" position controls attached to the feature of size dimensions in each direction (vert & horiz); if the feature is cylindrical, then you can put them inline with "blank value" horizontal & vertical size dimensions respectively. In this case a position control of .010 vertically and .007 horizontally with the BASIC horizontal location shifted to the right (+ve) by .0025. You can't use unequal tolerance zones for position (i.e. +.006/-.001) controls.
Jim Sykes, P.Eng, GDTP-S
Profile Services
TecEase, Inc.
