Guys,
I'm a mechanical engineer, with very limited knowledge on soil. i have to design a structure for pipeline crossing on a VERY SOFT CLAY.
Problem is, from survey report there is no Su recorded in the bore holes. going downstrem to the next bore holes, there is an Su recorded, at 0.7m depth, about 3.9kPa. Going upstream, recorded Su is about 1.7kPa.
Therefore, i assume linear relationship between the two points and got a 2.5kPa at the crossed pipe. However, this value is not suitable for concrete design as it will be very heavy in mid air.
My question is:
1). What is the range of Su for a VERY SOFT,GREENISH CLAY? I know the max is about 12kPa? I'm looking at something that is official, and written. Braja M.Das didn't give any range in his book. I need the min value for conservativeness purpose.
2). Does assuming a linear relationship between two points is acceptable? can it be used as a based of arguments?
Thanks..
My question is:
Thanks..
