MechanicalEngineer20
I am a new ANSYS user as well as new to Finite Element Analysis in general. I am having difficulty grasping the concept of steps and substeps. I tried searching for answering online, but could not find any sources that directly spelled out and helped me understand what substeps are.
As far as my understanding goes, a step is just a percentage of the applied load. For example, I could have 10 steps in total and start on the 5th step and end of the 6th step and that would apply 50-60% of the load correct?
My second question is dealing with ANSYS the "Define By" option under "Analysis Settings." When switching from program controlled to define by substep, what does initial, minimum and maximum substeps mean? Is this just the set amount of substeps in between the set steps I chose in the "Step Controls" option?
Thank you for your help.
