Thank you. It is correct that I am using a push pin design. I actually have 2011, not 2003 (R2008), but I know the section that you are talking about which deals with push pin design (5.2.6b of 2011).
It is interesting that you bring up the gage tolerance as a percentage of part tolerance, because Section 4.5.1 of 2011 states “If 5% to 10% of the tolerance on all features being gaged is represented in the gage, consideration should be given to the entire gage tolerance that has accumulated. It is recommended that this tolerance not exceed 50% of the tolerance for the specific workpiece feature being gaged. For example, if a pattern of holes is being gaged for a position tolerance and the maximum position tolerance for the holes is 0.3 (which includes any possible bonus tolerance drawn from the size limits of the holes), then the gage that inspects that hole pattern (which may include the gage flatness tolerance on the primary datum feature simulator, the size tolerance and the perpendicularity tolerance on the secondary datum feature simulator, the size tolerance and the position tolerance on the tertiary datum feature simulator, and the gage pins size tolerance and position tolerance for the hole pattern), when added should not exceed 50% of the 0.3 part tolerance on the holes."
Am I misunderstanding this section, or has the recommendation of the standard changed?
Part of my issue is that I am in a group which has designed many gages in the past, but we have lost a significant amount of experience due to retirements. I spend a lot of time looking at gages we have designed, and wondering why certain things are done, but I cannot seem to find answers. One of the things I have noticed is that, with pushpin designs, there is always a diameter difference between the part of the push pin that engages with the gage, and the part that engages with the part, exactly as you have recommended. My initial thought was that that would be undesirable, for the reason that you gave - it adds an additional tolerance (the positional tolerance between the two diameters) into the pushpin.
Could you more fully explain why you think this is desirable? I am not disagreeing with you - I don't have enough knowledge to disagree with you! I just want to understand.
