I am working on a home renovation where the addition will undercut the existing foundation of bricks resting on soil. (Before anyone freaks out, this is the common type of construction around here in early 1900s homes, and they're usually rock solid.) I have checked the existing foundation and there's no signs of movement, cracking, etc. The foundation is 24' long and has two stories and a basement wall above it.
To achieve the required headroom, the finished floor elevation of the lower level of the new addition has to be about 16" lower than the existing, and is directly in line with the bottom course of brick foundation. I plan to underpin in 3' long sections, with at least 6' left between the sections being worked. So, a few questions:
1. Do I encase the lower portions of the brick, or just pour up to the bottom?
2. For such a small section being worked, do I need to mess with needle beams?
3. Do I put rebar in the concrete or just mass concrete?
4. How do I connect the sections together - drill and epoxy rebar?
I've googled around and haven't found a good reference for underpinning methods, so I'd be grateful if anyone knows of one.
thanks,
Linnea
thanks,
Linnea
