I am not aware what your climatic conditions are.
Around here, (Minnesota) the depth of bury required to prevent freezing also gives a stable temperature of around +/- 50 degrees F. This means that insulation is not really needed. There is not enough of a delta T to economically justify insulation. The thick walled plastic pipes that are typically used have a signifigant R value in themselves.
