Hi there,
There are a set of cables in PVC ducts with concrete casing running underground up to a hill. A field work is going on to dig into the soil underneath the cable ducts and move the soil out. Eventually, the cable ducts will be exposed to air but somehow supported above ground.
As I know the cables are 13kV and paper insulated.
Does any one know that in this case, to be safe and keep the cable fuctional,any considerations to be in place? the 13kV clearance will not allow people to work too close to the ducts when the cables are on line, right? - like shovelling around it? The temperature rise when the cables are exposed under the sunshine will cause possible aging/other problems?
Many thanks!!
Many thanks!!
