curtis2004
- Jan 8, 2010
- 301
Hi everyone,
1. I have water and condensate drain CS lines going U/G which shall be insulated and heat traced to the portion above frost line. Is there any guidelines what materials to use for insulation cladding and heat tracing?
2. I have a concrete storm water basin with submerged water pump in the bottom, which will pump water away. Water lines is changing and may freeze in winter if not pumped out entirely. Is there anything shall be done in order to protect pump and vertical CS pipe line from freezing? My first thought was to protect it from freezing by insulating and heat tracing both pump and line. However, now I am more inclined that maybe small heater inside pipe may suffice. Did anyone had similar project with pumping out water from open pond?
Thanks,
Curtis
Thanks,
Curtis
