cvanoverbeke
I just received an geotechnical report for an undergound parking garage which has some issues since it is below the water table. The geotechnical engineer states thtat the slab on grade floors should be independent of load bearing walls and columns. This is going to be the case.
However they state the floor slab should be design for a subgrade reaction (k) of 30 MPa/m. Can someone explain this reaction force?
Cvanoverbeke
Cvanoverbeke
