Ysaac
- Aug 3, 2009
- 17
Steam turbine blades are designed and tuned for operation at a rated frequency rotation. So, under and overfrequency protection, especially underfrequency, are used to prevent blade ressonance and fatigue damage in the turbine when it´s runinng with load (system conected) out of frequency range. So, once in this condition the turbine should be removed from system.
Well, imagine that a fault in the system results in islanding of plant and the speed regulator was not able to regulate and the frequency of plant reach a value considered critical (underfrequency caused by a overshoot of overfrequency) to a turbine: 100% or 70% i.e loaded.
My question is: Since that the plant at this moment is providing energy to its auxiliar service, should I trip the turbine considering it is operating in the same critical frequency value? In other words, is the operating without load and out of frequency range as dangerous as the operating with load and out of frequency range?
