I design equipment with plate and C channel stiffeners welded to the plate to resist internal pressure loads, ductwork for power plants, to be specific.
If the free flange, away from the plate, is in compression, what is the maximum length for the channel to run without cross bracing if it is designed to a maximum stress of .6Fy in the composite shape? What is the relationship of allowable stress to unbraced length when length is greater than the first case?
