machstruk
- Mar 3, 2010
- 5
Hi everyone,
I have a question about hoist beam and I have a situation that is similar to the one shown in AISC presentation (Design of Underhung Hoist and Crane Girders, in terms of configuration except that instead of engineered clamps(as shown in the attached picture) the top column post and brace is welded to the hoist beam.
The question is, what unbraced length of hoist beam should be considered for LTB for given configuration? Can the vertical post be considered to provide enough lateral restraint to top flange and that the unbraced length can be considered as distance between two vertical posts ? or should additional bracing (minor axis to hoist beam) be provided and linked back to the floor like done in the above mentioned AISC presentation with the joist system.
There are multiple posts as the hoist beam is continuous and the above mentioned AISC presentation recommends considering hoist beam bottom flange for LTB as it would be in compression where beam is continuous. Would the correct method for determining bottom LTB span be to calculate the distance from post (support) to inflection point and use that length as a cantilever beam with end conditions using the K coefficients shows in the presentation?
I have also attached a paper by Trahair that offers another method to calculate underhung hoists beam strength for various top flange lateral and torsional restraints. For the aforementioned situation, do you think that the vertical post would provide a rotational restraint to the top flange since the attached post has minor axis stiffness which can be effective in preventing rotation of hoist beam top flange.
Thank you in advance.
Best Regards,
Best Regards,
