Unable to obtain results on column
  • Thread starter Thread starter msiva1981
  • Start date Start date
M
msiva1981
Guest
Hi all,
Iam running a simple frame analysis on Pro Mechanica. i have attached the fringe plot of displacement. I am unable to plot a graph plot of displacements on the columns. It also says no information is available for columns eventhough i could see defelctions on columns.Help me out here. I have been fighting this frame problem for a very long time now and have sent 6 posts in the last week. It would be great if someone who has done such an analysis help me here. Needn't be long. Very short. Iam ready to send files across if need be too
Siva
Post the files. You appear to have a translational constraint of '0' at the junction of the column and the beam. Movement would occur here under loading - it's inevitable. It wouldn't be unreasonable to use rotational constraints between the members however.
Phil
Hi pjw,
Iam having some issues with my computer. Shall post it soon
Siva
Hi Siva,
I noticed that when you created your Pro/E curve for the beams, you used "curve through points":
If you create your Pro/E curve using the "Sketch Tool" instead, then you will not get the above issue:
