Unable to load the CATProduct
CATPart
Automotive
Jun 12, 2006
115
I'm trying to open the main CATProduct which is made of sub CATProducts and CATParts... V5R14 SP5 HFix15
Catia starts to load the files, and after some 30% pops up the window with text in Title bar "A CHECK ON DATA WILL BE LAUNCHED ON ACTIVE DOCUMENT" and text saying "COMMAND INTERUPTED".
When I click OK, Catia stops responding, i have to use Task manager to shut her down.
The subproducts I can open without problem.
Please help...
Damir
Damir - Try CATDUA from the utility page. Can you open the sub assemblies on their own?
Derek
Yes, sub assemblies are working fine.
CATDUA I have already tried without success, but I think that I have accidentaly changed the file name of one sub assembly... the problem is that I have unchecked te option TOOLS/GENERAL "load referenced documents" and still cannot open the main assembly
Funny thing is that with unchecked above option in R16 at home I can open the product and delete the problematic sub product... at work I have only R14
This the new factory layout, and I can rebuild this product quickly but I'm missing only the possition of equipement.
So I will take the position from R16 At home and rebuild it at work.
Thanks Derek,
Damir
