Unable to find material: PAN Bz14
starflex
Materials
AU
Hi There,
Hopefully some of you can shed some light on this material : PAN Bz14.
It would appear a Bronze/Tin alloy, but I cannot find any additional information about the nominal chem composition. It's quite hard to source (not impossible, just hard) and having the exact chem compositionwould help greatly.
Any idea ?
Thanks,
P.
this is a cast alloy of a german company:
with just Cu and 14% Sn.
However, they have a proprietary method of manufacturing / treatment which make parts from these alloys quite better than products with comparable alloys from other mfgrs. I.m.exp. these materials are worth the extra mile / $, if you need to stick to Cu alloy.
Roland Heilmann
Lpz FRG
RolMec,
Exactly what I recommended to the Client, thanks for your input.
I was looking at the specs, and I noticed that the mech properties (tensile and hardness) are quite unusual for a "soft" bronze.
Recommended to go with the OEM.
P.
