the radii are causing the problems here. You can either use the 'remove' tool to get rid of the radii, convert to sheet metal then add radii after, or possibly copygeom the outside surface into a new sheetmetal part and then offset. Attached is an IGES of the part created like this in creo 3 that will convert to sheetmetal in WF2
regards
