I am looking to provide a rating for an industrial control panel with solid state relays (using UL 508A Supplement SB).
I've been unable to find a reference to which standard the "available short circuit current" must be calculated.
When rating gear and breakers, it is obvious - ANSI equipment uses the ANSI C37 standards, IEC equipment uses IEC60909.
However, for UL listed equipment, I have not come across the reference for which method is required.
Does anyone happen to know this?
Thank you.
Thank you.
